Focus ST engine into XR2?
Old Nov 13, 2007 | 12:17 PM
Taylor's Avatar
Taylor
Default Focus ST engine into XR2?
Just wondering if anyone knows if it would be possible to fit the Focus ST engine into an XR2?
Track car needs a rebuild and got offered the full front end of a Focus at the weekend that has been smashed,so was just wondering if anyone has any info.
Old Nov 13, 2007 | 12:20 PM
Twellsie's Avatar
Twellsie
i take it you mean the ST170 engine, if so i have seen a couple of fiestas running those engines
Old Nov 13, 2007 | 12:25 PM
Taylor's Avatar
Taylor
No mate,the Focus ST not the ST170
Old Nov 13, 2007 | 12:27 PM
SNP's Avatar
SNP
Default Re: Focus ST engine into XR2?
I'll probably be shot down and slated, but the simple answer is yes.
Reason being you can put pretty much any engine into any car as long as you have the skill and budget.
Old Nov 13, 2007 | 12:32 PM
Shonky's Avatar
Shonky
V6 Ka of Love
It'd be tight I recon, the motor is quite a lot wider than the 4 pots and the engine bay isn't very big, if the gearbox is not very wide you may well fit it in, I'd get the measuring tape out
Old Nov 13, 2007 | 12:37 PM
Twellsie's Avatar
Twellsie
get it built, would be a monster!!
Old Nov 13, 2007 | 12:51 PM
Taylor's Avatar
Taylor
This is kind of what i was thinking that it may be too wide. As you say though will be well worth having a measure 1'st!
Old Nov 13, 2007 | 12:52 PM
Taylor's Avatar
Taylor
My thoughts exactly!
Cheers to all for the input.
Old Nov 13, 2007 | 01:01 PM
xr-stu's Avatar
xr-stu
nowts imposible but id imagine the best way to do it without reducing the structural strength of the front end to much would be to space frame the front end and tie it into a weld in cage. youll need to chop alot of chassis leg out id imagine otherwise.
Old Nov 13, 2007 | 01:46 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Would you not be better with the focus RS engine? Surely it would be lighter and more suited to your car.
Benni.
Old Nov 13, 2007 | 02:21 PM
Taylor's Avatar
Taylor
Benni.
Every chance that is correct mate but was just wondering as i got offered the chance of an ST engine at the weekend.
Chances are that the car will be rebuilt with another big spec CVH but was just wondering after i got offered this and the price i got offered it at!
Cheers Taylor
Old Nov 13, 2007 | 02:49 PM
AustenW's Avatar
AustenW
Benni.
The Focus ST 5 cylinder engine is all alloy and lighter than the ST170 Zetec engine
I've got both in my garage
Old Nov 13, 2007 | 03:03 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
also isnt the gearbox sorter to make up for it, so overall its no longer than a zetec etc and box?
they fit in the focus, and so does the duratec...
go for it, and when its done, let me know and we will feature it!
Old Nov 13, 2007 | 03:42 PM
Taylor's Avatar
Taylor
If only it was that easy lol!
Don't worry if it gets done then i will drop you a shout!
Old Nov 13, 2007 | 04:06 PM
Taylor's Avatar
Taylor
The box that it is the car just now is a Straight cut Quaife for a CVH so ideally i would like to keep using that!
Old Nov 16, 2007 | 12:23 PM
Taylor's Avatar
Taylor
BTTT!
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
