idle control valve
Old Jan 23, 2004 | 05:28 PM
steveRS's Avatar
steveRS
Default idle control valve
can someone tell me what does it exactly do?
when you set the co2 you unplug it!
if it was wonky in some way what probs would it cause???
regards
steve
Old Jan 23, 2004 | 06:48 PM
3door's Avatar
3door
to set car up get the co2 checked to see this is correct for ur set up..if car is modded then co2 will be higher.as a guide my stage 3 is running about 2.7% at idle.get car warm and disconnect iscv.set base idle by adjusting via the the bypass valve under the plenum at the front to about 850rpm then reconnect iscv idle shdnt alter /might lightly rise and drop again.i have a new one and it still sticks about 1000rpm sometimes.symptoms of dodgy valve are a bit hit and miss as with most things a fluctuating idle can also be caused by other things...are u having any specific probs..once all adjusted double check co again
Old Jan 23, 2004 | 07:05 PM
steveRS's Avatar
steveRS
mine is set to 3.0% as when i go to pull away it stutters, also when i pull up the revs go down then up abit then back to normal!
on way home from "the emporium" lol, i pulled up at lights and the revs were stuck at 1.200 rpm abit later went to normal
regards
steve
Old Jan 23, 2004 | 11:33 PM
Stu @ M Developments's Avatar
PassionFords Creator
Throttle sensor sounds a good culprit... as do excesively small plug gaps on a poor plug like C57.
Old Jan 24, 2004 | 05:47 AM
steveRS's Avatar
steveRS
stu
plugs set at 6.5mm they are ford motorsport platinums...
were do i find the throttle sensor please ?
regards
steve
Old Jan 24, 2004 | 08:53 AM
3door's Avatar
3door
stu mine is a stage 3 with hybrid t34/running about 25psi and it stutters a bit when cold and revs sometims stick at about 1000rpm but not allways..tps seems fine as secs monitor reacts correctly/what plug shd i put in and what gap and last of all how much are they incl postage
Old Jan 24, 2004 | 09:07 AM
Hi,
TPS is to the left of the throttle body, opposite side to linkage.
Plugs at 0.65 are too small for a stage 1, go for 0.7 - 0.75 (Stick with .65 for 25psi)
Best plugs for a stage 1, price wise are std esc cos AGPR 12PP8.
Performance wise, go for the NGK9 at around £65 for stg 3 and above cars.
Cold running issues are VERY common on cosworths and can be down to a lot of different things unfortunately, but start with the above.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
