Flurosilicone Lined Silicone Hoses
Has anyone used the Flurosilicone lined hoses for fuel filler neck pipe ?
They are sold as fuel and oil resistant but after some questions / info I recived from a supplier ‘Quote’ :
“If there is petrol passing through the hose then I have to say that I wouldn't use any silicone hose even with a flurosilicone liner in it. Although it probable would do the job I won't guarantee it”
Just wondered if anyone had tried them and what, if any bad / negative effects you had had.
Cheers for any replies.
WD
WD
Originally Posted by WD Pro
Anyone ?
its very very expensive stuff @ £70 a metre, if you need some i have about 3/4 of a metre for sale, its a 19mm internal diameter and i only used a bit for my oil return to the sump.
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
