noisy lifter ?
Old Nov 10, 2007 | 07:03 AM
coswurv's Avatar
coswurv
Default noisy lifter ?
Got a little niggly problem with the cossie, when i pull away and keep the revs at 2k i get a tappity noise from the head i think its a lifter ?, when the engine is under load it doesnt do it as bad if at all do you guys think its just a noisy lifter ?
Old Nov 10, 2007 | 08:06 AM
moonstone mike's Avatar
moonstone mike
I get a rattle when i hold the revs at 3500
only hapens at this speed no other rpm??
sounds like the same prob as me mate ....i was told it was a lifter!
would like some more light on this to.
Old Nov 10, 2007 | 11:26 AM
coswurv's Avatar
coswurv
yeah exactly the same mate, just mine does it a 2-2.5k then goes away soon as you plant the throttle and put load on the engine
Old Nov 10, 2007 | 12:06 PM
lukemakepeace's Avatar
lukemakepeace
sounds like lifters. are you sure it just goes because a combination of the engine noise and the spped the lifters are now moving over power the original tapping sound?
Old Nov 10, 2007 | 08:44 PM
Csm's Avatar
Csm
My old cossie did this
so fookin annoying hearing a rattle tho
Old Nov 10, 2007 | 10:24 PM
lukemakepeace
seriously, i did mention the lifter treatment, try it, it does work, and its better also cheaper than replacing lifters!
RUBY123
Oct 22, 2023 12:04 PM
Roosie
Aug 13, 2015 07:40 PM
slowpoke
Oct 14, 2004 02:06 PM
cossieminor
Aug 17, 2004 09:06 PM
