how much bhp and how much am i losing
hi guys,
my rst had an engine rebuild 10 months ago, its got a hybrid stage two, dash 31, piper 285t2, chipped, stainless system and air filter what bhp roughly,
but my stainless system is twin exit alot of ppl have said im losing power by having it anyone know how much.
I don't think you would be losing power as long as the system isn't restrictive!
There is probably better exhausts out there but they will only improve it by a few bhp if anything.
You should know your bhp when you got it setup! about 190 at 15psi??
If you want more power, as a starting point change your management
alot of ppl use gotech management is that the way to go i also want to put new rad and front mount intercooler but not sure what one to go for
I use gotech and yes its very gd
If your rad needs replacing then get the original one otherwise give it a good flush.
Intercooler wise, I have radtech frount mount which I highly recomend unless you like to spend alot of money just for the name.
