fluffing
Old Oct 12, 2007 | 07:07 PM
cossykiller's Avatar
cossykiller
Default fluffing
i have 4x4 saf my problem is the rev counter starts bouncing eratic like and the car starts fluffing and holding back i tried new coil and disconecting rev counter makes no differance oh and its an intermitant problem any sugestions i dont want to just throw dosh at it and hope
Old Oct 12, 2007 | 10:39 PM
dave cos4x4's Avatar
dave cos4x4
most probably a bad earth,check them all over.
Old Oct 14, 2007 | 08:17 AM
Check the cps connector by wiggling whilst it is idling.
Old Oct 15, 2007 | 11:16 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
What he said, these usually get full of water. However, once they start to give problems, it is usually best to replace them .
Old Oct 15, 2007 | 06:51 PM
My cossies crank position sensor was full of water. This was causing faults on my car when i first bought my car. I cleaned the connection out and put electric tape round the connection to stop anymore water getting in.
Old Oct 16, 2007 | 04:34 AM
velocity's Avatar
velocity
this is a regular thing on the cozzy and can be caused by bad earths on the inlet manifold and elsewhere on the engine,also the 3 big block connectors at the back of the engine bay are also known to be a cause of this problem,have a check of all the engine earths and open and close the block connector a few times to make a good connection and do the same with the ignition amplifier connector
Old Oct 20, 2007 | 06:07 AM
I will have two have a look at my car. Its mad cause the fault with mine is only every now and then.
M K
35
Aug 12, 2015 09:28 AM
youngben
Sep 7, 2014 09:06 AM
scoooby slayer
54
Jul 2, 2012 03:59 PM
RS 500,
Dec 20, 2009 05:15 PM
