dump valve
Old Oct 8, 2007 | 08:07 AM
Spanthefestaman's Avatar
Spanthefestaman
Default dump valve
At what point should you start to think about having a dump valve?
im doing a ZVH that has a stage 3 turbo and is running around 15psi, the car is used for track purposes only.
while its running in it should only be at around 10psi but when its setup it will go to around 15psi.
Old Oct 8, 2007 | 11:07 AM
antony215's Avatar
antony215
Escort Rs Turbo
You dont really need a dump valve unless your running stupid boost like 35psi+ and even then it's not critical to have one
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
