escort series 2
Old Oct 4, 2004 | 05:40 PM
leespiro's Avatar
leespiro
Default escort series 2
hi all does anyone know about rising fuel pressure
i took my rs turbo to be rollin roaded he had it the the rollers only taken the revs to 3 grand then he tell me ive got no rising fuel pressure any ideas
Old Oct 6, 2004 | 08:07 PM
b13nde's Avatar
b13nde
im not sure i think its the control box on the right hand side of the injection unit check the wiring on it but behind that box is a screw and then behind that is a allen key turn it clock wise to increse the fuel pressure and anti clock wise to decress it try that but you only need to turn it 5 to 10 degrees and no more or youll blow fuel lines off and start a fire under there
Old Oct 6, 2004 | 08:21 PM
Rick's Avatar
Rick
complete bollocks is what he said. The fuel box is a secondry fuel correction system. U cant tell anything at 3000 rpm really.
Old Oct 6, 2004 | 11:23 PM
b13nde's Avatar
b13nde
you what whos that adressed to[
Old Oct 7, 2004 | 01:33 AM
velocity's Avatar
velocity
are u sure he didnt say boost pressure
Old Oct 7, 2004 | 05:06 AM
JesseT's Avatar
JesseT
Don't know what the tuner actually meant, but the fuel pressure, controller by the main fuel pressure regulator, is not supposed to rise. Most efi-cars have a rising rate fuel pressure regulator giving a fuel system pressure of 2 bar + manifold absoute pressure. If he wasn't familiar with RSTs, then he might have noticed this.
If on the other hand, he knows the RSTs inside out, he might have meant the electric control pressure actuator. This is what b13nde was on about. The fuel control pressure only takes care of all fuelling corrections like acceleration and WOT enrichments and overrun fuel cut off.
jessie_rs
Jan 5, 2016 01:16 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
jessie_rs
Sep 7, 2015 01:27 PM
gingeRS
Sep 4, 2015 06:29 PM
turbowag
Sep 3, 2015 08:07 AM
