Very hot s2
Old Jan 20, 2004 | 07:41 PM
Default Very hot s2
Hey
I just can't seem to get my s2 to stay cool. I have changed the thermostat, the rad (twice) just put a new one in last week. And I've changed the waterpump, and the sensor (both new from ford) It's got standard ic, and is running standard boost.
When i drive it at summer it stays above the "N" in normal and when I stop at a traffic light, it goes into the red in like 30 seconds.
When it's winter, like now, and snow and stuff, it stays just under the middle, but still climbs to just below the red at traffic lights.
But the strange thing is that when I start to drive again, it goes from the red and to the middle in 10 seconds..
Someone please help :
Old Jan 20, 2004 | 11:27 PM
PJay's Avatar
PJay
Mine done that when the fan wasn't working
Old Jan 21, 2004 | 07:24 PM
Hey..
The fan is working, I've checked it sevral times
Old Jan 21, 2004 | 07:35 PM
PJay's Avatar
PJay
OK, air lock or blockage
Old Jan 21, 2004 | 07:59 PM
Ok, damn. How do I find the problem then... or is that gonna very difficult?
Old Jan 22, 2004 | 12:36 AM
PJay's Avatar
PJay
I would start by bleeding air from the system, do a search for inst, if not that it's pretty common for the heater matrix to get blocked, are the cars heaters etc working ok?
PJay
Old Jan 22, 2004 | 06:53 AM
Hey
yeah all the heaters are working fine, but the air coming out of it, is so hot than you cant put your hand infront of it..
What do you mean by bleeding air from the system?
Old Jan 22, 2004 | 12:36 PM
tonyk's Avatar
tonyk
You leave the car idling with the coolant expansion tank cap of until there is no bubbles appearing.
Old Jan 24, 2004 | 11:11 AM
Hey
Done that today and the car is still getting hot
Old Jan 26, 2004 | 07:52 PM
o n i o n's Avatar
o n i o n
Shot in the dark here bud, but is your fan wired up the correct way round so it actually draws cold air inwards and not hot air outwards.
It may also be a good idea to wire your fan through a relay,triggered by your fan switch to take the power directly from the battery. (Fused of course)
You may find your fan will run faster.
HTH
Old Jan 26, 2004 | 08:21 PM
Fozy's Avatar
Fozy
Worse case is that your head gasket is gone or on the way out. Check to see if there is any oil in the water or water in the oil.
Old Jan 27, 2004 | 02:32 PM
Onion: I have checked and my fan does work the right way, but to wire the fan directly to the battery is a very good idea, thnx
Fozy: I have did a test once were they put a thingy, down the header tank, that would turn in color if the gasket was gone.. But I'm beginning to think it has to be the gasket..
Old Jan 27, 2004 | 05:10 PM
Windle's Avatar
Windle
Does it get hot quicly if you start to hold it on boost through the gears or just in traffic ?
Old Jan 28, 2004 | 08:31 PM
It's just in traffic.. well if i do 120 for some time it get hot too, but the it's worst in traffic.
Old Feb 2, 2004 | 04:11 PM
Have you tried taking the thermostat out and running it with out one?
I normally end up doing that with most of my escorts for one reason or another
Fiddy
21
Sep 29, 2015 06:10 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
