Manual cooling fan question?
Old Sep 30, 2007 | 09:02 AM
seanex's Avatar
seanex
Default Manual cooling fan question?
My RS hasnt got the fan connected through the loom, there is a switch I could use inside the car but being a newbie could anyone give me an idea of how to wire it up to the switch
Thanks
Old Sep 30, 2007 | 11:10 AM
Wardy257's Avatar
Wardy257
All you need is a relay, wire and the switch. You run a permanent live to the fan and have the relay on the earth wire from the fans. Rig the switch up with a ignition live to the the relay and the switch on the earth wire from the relay.
Old Oct 1, 2007 | 12:42 AM
seanex's Avatar
seanex
Cheers Wardy, top man
Old Oct 1, 2007 | 06:58 AM
Aaroncast's Avatar
Aaroncast
if you go to the kenlow electric fan site you will see a thermal switch which allows you to vary the switch to your temp of your water in your rad!!!!
using a ordinary switch you stand the chance of -BOILING /COOKING THE ENGINE!!!!____________if you havent got an eye on it!!
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Chas
Oct 5, 2015 07:13 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
