side lights not working
Old Sep 20, 2007 | 07:23 PM
trossnova's Avatar
trossnova
Default side lights not working
ok my side lights are not working and nor the no. plate light etc or the dash
the rear lights only the brake light works
their is no power to the fues for the lights so is this a relay?
any help would be great
Old Sep 20, 2007 | 07:31 PM
Unlikely that a relay will cut all this out.
Check for power at the light switch itself as this is the first thing to do, and what car, escort mk3/4 ?
Old Sep 20, 2007 | 09:50 PM
trossnova's Avatar
trossnova
escort mk 5 1992
Old Sep 20, 2007 | 10:09 PM
messcortmk6's Avatar
messcortmk6
it surely dosent sound to be a relay. may be a problem with a switch somewhere.
Old Sep 20, 2007 | 10:37 PM
BigMouthBillyBass's Avatar
BigMouthBillyBass
My mate had a similar problem, exterior lights werent working as they should (intermittent) and dashboard, speedo, heater switches etc stopped lighting up
faulty indicator stalk was to blame (The switch for the lights is on the end of the stalk i seem to remember), common problem with the Escorts apparently
Old Sep 20, 2007 | 10:52 PM
jawanne's Avatar
jawanne
hi i had the same prob with my mk5 i just put a wire from my ignition with a fuse on it....so i put i live in to where the fuse goes have a look if that works it worked ok on mine
jaysoc1
Aug 20, 2015 08:18 PM
CrOwSoN15
Aug 14, 2015 06:52 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
