ERST Electrical fault
Old Sep 11, 2007 | 08:31 AM
MorryRS's Avatar
MorryRS
Default ERST Electrical fault
Hi
My escort keeps blowing the fuse for thr RH lamps its fuze 17 i thinkand also my dash illumination is not working too . Im not sure if this is off the same circuit.
Any ideas
Old Sep 11, 2007 | 01:30 PM
Dash ilumination is taken off of one side of the sidelight circuit, so it would seem that it is the same one here.
First take out the bulbs front/rear to see if it still blows, as a duff bulb can do it(shorted inside).
If not it is a case of examining the wiring to find a live that has gone to earth, using a metre(resistance) is easy enough though can be time consuming.
Old Sep 11, 2007 | 10:01 PM
SafeChav's Avatar
SafeChav
Have you got lots of gauges wired in behind the dash or anything like that by any chance?
If not its more than likely going to be something shorting either in the engine bay or the rear light cluster. The rear lights are prone to electerical faults on these cars anyway.
Old Sep 13, 2007 | 01:58 PM
MorryRS's Avatar
MorryRS
Cheers folks . Got the problem sorted it was the loom at the footwell was shorting against the chassis
CheeRs
Old Sep 14, 2007 | 03:21 PM
SafeChav's Avatar
SafeChav
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Kam B
Sep 24, 2015 10:40 AM
