RS2000 MK5 VAN CONVERSION
Old Sep 2, 2007 | 09:04 AM
RSVANMK5's Avatar
RSVANMK5
Default RS2000 MK5 VAN CONVERSION
WHAT IS INVOLVED IN PUTTING A MK5 RS2000 ENGINE AND RUNNING GEAR INTO A MK5 VAN?
Old Sep 2, 2007 | 02:15 PM
gup's Avatar
gup
quite alot fella im doing this conversion soon ive picked the rs 2000 up
lump should go in without to much trouble
then the tank is gonna be a head ache
gotta run new fuel lines (i am )
loom i am splicing in the mk5 engine loom into my mk6 van
ive got a digi speedo so that should be fun to wire up
Old Sep 2, 2007 | 05:20 PM
RSVANMK5's Avatar
RSVANMK5
Default rs2000
y dnt u just put the full loom out of the rs2000 in instead.thats wat iam planning on doing
Old Sep 2, 2007 | 05:39 PM
gup's Avatar
gup
you can use a full loom
but ive got a mk6 van with an airbag which i would like to keep and i dont like the mk5 switchs and dash fella
Old Sep 4, 2007 | 06:57 PM
RSVANMK5's Avatar
RSVANMK5
Default rs2000 petrol tank
in wat way will the tank be a headache?
Old Sep 4, 2007 | 09:33 PM
gup's Avatar
gup
our vans use a lift pump ie (vacum)
where as a petrol car uses a fuel pump to pump the fuel into the engine bay
so you will have to make a return for the tank and also have to try and mod a petrol tank to fit like the mk5 or 6 tanks have the pumps in the tank where as a s1 or 2 have a pump on the outside
if you this makes sense lol
mk3ste
Oct 17, 2021 10:09 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
SMILER258
Sep 28, 2015 09:04 AM
