Getting the thing into gear?
Old Sep 29, 2004 | 08:18 PM
Paulr's Avatar
Paulr
Default Getting the thing into gear?
Hi all.
On my erst i am experiencing problems engaging gears now and again.
Some times they just slip in and other times its quite difficult to select. As far as i am aware the clucth seems ok, so is the gearbox on its way out or could this just be a case of fitting new mounts?
Paul
Old Sep 30, 2004 | 04:07 PM
crazyshad1's Avatar
crazyshad1
I HAD THE SAME PROBLEM WITH MY FRST, TURNED OUT IT WAS THE SPRING ON THE CLUTCH PLATE. WHILE I HAD THE GEARBOX OUT I ALSO PUT A NEW CLUTCH IN
Old Sep 30, 2004 | 05:02 PM
sammy's Avatar
sammy
i would get the gear selecter checked for alignment or excess wear before taking out the box
Old Oct 6, 2004 | 08:19 PM
b13nde's Avatar
b13nde
gear linkage is always a fav nats cock out of aline can screw it all up
Old Oct 8, 2004 | 07:06 PM
S1MAN's Avatar
S1MAN
I'd try to adjust the gearlinkage first
Old Oct 9, 2004 | 07:20 PM
mkv_turbo's Avatar
mkv_turbo
is there an easy way to adjust the linkage or is it just trial & error
DHMC
Ford Fiesta
Sep 30, 2015 07:15 PM
Fiddy
21
Sep 29, 2015 06:10 PM
`spotty
Sep 25, 2015 11:41 PM
IainRS1700T
Sep 25, 2015 06:44 AM
cameron2
Sep 20, 2015 04:30 PM
