uneven tickover when cold
Old Aug 19, 2007 | 04:33 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Default uneven tickover when cold
any ideas? its ok when it warms up
Old Aug 19, 2007 | 08:58 PM
Daxcossie's Avatar
Daxcossie
Idle speed control valve might need a clean ?
Old Aug 20, 2007 | 07:47 AM
As said ISCV clean and LUBRICATE, then look at CO, could be out, set o around 2.5% co.
Old Aug 20, 2007 | 12:50 PM
Retro Al's Avatar
Retro Al
RWD IS KING
ok how do you set co? cheers
Old Aug 20, 2007 | 01:55 PM
Go to local friendly MOT place and slip them a fiver(?), simply a case of turning the CO screw, if it has one(?) depending on what level ecu you are on, counterclockwise to richen, clockwise to lean off.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
xrmalin
Sep 13, 2015 06:52 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
