escort gti temp guage
Old Aug 19, 2007 | 11:36 AM
sparks3107's Avatar
sparks3107
r sparks
Default escort gti temp guage
[color=red]help!!! got a 1998 r reg gti temp sensor literally went bang!! [/color]due to a wiring fault on fan wiring repaired wiring to fan replaced engine coolant temp sensor for ecu and cooloant sensor for the guage, fan cuts in at 90c as normal according to wds/ids (ford diag computer) but temp guage goes all the way into red ign on, engine running back to below cold where it remains?? checked voltage to coolant sensor 14v engine running 8v ign on, all wiring seems ok? replaced clocks still no gauge? is it pcm controlled i.e 5volts or should it be batt+ voltage?? have i spiked pcm or fuse box? car runs ok and everything else still works please can some one shed any light?????? [size=18][/siz
Old Aug 19, 2007 | 01:28 PM
Wardy257's Avatar
Wardy257
Sounds like you have a wiring fault. All the ZETEC sensors are 5v.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
15
Oct 7, 2015 03:43 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Ben26
Sep 3, 2015 07:55 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
