Distributor on a 3dr
Old Aug 18, 2007 | 06:18 PM
Moonstone Kev's Avatar
Moonstone Kev
Default Distributor on a 3dr
How easy is it to change a dizzy on a 3dr
Old Aug 19, 2007 | 08:41 AM
If you can inflate the tyres you can change a dizzy.
OK that might be a slight exagertion!!, but it is really easy, may as well do timing belt/tensioner at same time(if needed) ?
It is a bit fiddly to get to the 13mm bolt holding the clamp at the base of the dizzy, more by feel than sight, but take this off and it just pulls out, noting it's position first, then you do not even need to disturb belt if you don't want to, would probably be better to line up on tdc first though.
Old Aug 19, 2007 | 09:26 AM
Moonstone Kev
Thanks Tabetha
Old Aug 19, 2007 | 01:16 PM
No probs did you get the piccies ok ?
Old Aug 19, 2007 | 01:23 PM
Moonstone Kev
Yes i did thanks alot
TPM961
Jan 15, 2018 10:50 AM
martynhomer01
Oct 1, 2015 12:05 AM
20/20 vision
Sep 29, 2015 11:27 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dms04
Sep 11, 2015 01:57 PM
