Fitted Koni's to S2, Need a definitive answer!!!
Old Aug 17, 2007 | 04:25 PM
Blakeya's Avatar
Blakeya
Default Fitted Koni's to S2, Need a definitive answer!!!
OK,
Fitted a set of Koni adjustables & 20mm lower & uprated springs to my Series2. The problem i have now is that the front sits to low & the rear to high. The front has dropped almost 50mm from standard & the rear is just about at the standard height. I have the springs the correct way round (Cant confuse them as they are diff diameters). What could possibly be the problem. All bushes have been replaced with poly's. I have run the car for aprox 200miles like this thinking that things may settle but still no good. Due to the front being so low the geometry is along way out (Massive Neg camber) which is most horrible to drive with.
Any ideas much appreciated.
Cheers in advance
Regards
Andy
Old Aug 17, 2007 | 05:52 PM
cos jon's Avatar
cos jon
When you swapped the springs over did you see what difference the old and new were like off the car ??
Old Aug 17, 2007 | 06:48 PM
djmillsy's Avatar
djmillsy
Fife Radge
i know this has happened to alot off ppl mate not sure of the remedy i was told they would settle after time mate but yours havent maybe best to take them off and check them
Old Aug 17, 2007 | 06:59 PM
Aaroncast's Avatar
Aaroncast
spring poundage at the front!!! spring heights/length !!!
Old Aug 18, 2007 | 08:57 AM
NUTS RuS's Avatar
NUTS RuS
Do you have the springs the correct way up ?
Are they progressive ?
Old Aug 18, 2007 | 11:27 AM
jawanne's Avatar
jawanne
make sure that you have the front springs on the front and the rear on rear .........................................
Old Aug 19, 2007 | 08:36 AM
Alex_86's Avatar
Alex_86
Old Aug 20, 2007 | 06:08 AM
Blakeya's Avatar
Blakeya
I'm Not aware that the springs are progressive. How do i tell if they are? & if they are which way up are they suppose to go? Does it really make any difference with a progressive spring if they are mounted upside down?
They are mounted on the correct axles by the way!
regards
Andy
Old Aug 20, 2007 | 08:34 AM
Alex_86's Avatar
Alex_86
what springs did follow? lefjords?
Old Aug 20, 2007 | 10:26 AM
Blakeya's Avatar
Blakeya
Koni!!
jessie_rs
11
Jun 3, 2019 04:57 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
neil18
Mar 14, 2016 01:08 PM
TrevCos
Modellers Corner.
Aug 24, 2015 09:31 PM
dal3door
Aug 13, 2015 06:55 AM
