modaeo tdci- glow plug warning light flashing--help
Old Aug 15, 2007 | 06:54 PM
palmer3914's Avatar
palmer3914
Default modaeo tdci- glow plug warning light flashing--help
help,
glow plug light started flashing and at same time ive lost all the surge expected from the turbo.......no smoke, noise etc...is it just a glow plug ? or some thing else......help save me money befor ei put it in to a dealer to diagnose.............
cheers
Old Aug 15, 2007 | 07:04 PM
This light if flashing must also act as a engine management light then.
All you can do really is check the the pipes etc have not come off and daft things like that, then dealer or code reader if you have one.
It will NOT be caused by a glow plug.
Old Aug 16, 2007 | 10:24 PM
James's Avatar
James
very unlikely it'll be something easy really.
cam senser or an injector are the likely causes.
boost pipe between inlet and intercooler is common but black smoke would normally be expected and it doesn't normally put the engine light on.
check the pipes, but be prepared for a trip to the dealer i'm afraid
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
fuzzy
Sep 4, 2015 10:11 PM
