Clutch and flywheel removal
Old Aug 14, 2007 | 12:53 PM
Micky's Avatar
Micky
Default Clutch and flywheel removal
I need to remove my clutch and flywheel to replace a leaking rear crankshaft seal on my RST.The Haynes manual makes it look very straight forward,BUT IS IT???One problem Im worried about is the clutch assembly or flywheel turning as I try to untighten the bolts.Will it,and if it does is there anyway of stopping them???The Haynes makes no mention of needing to lock the flywheel from turning.Regards,Micky
Old Aug 14, 2007 | 01:39 PM
You will find that if you leave the plugs in then this will help a lot, as a few sharp taps of the hammer on the ratchet handle will soon shake things loose, try to turn the ratchet across the flywheel, ie so it is somewhere over the face of the flywheel instead of out side pointing towards it as there is then less of a lever effect trying to rotate the flywheel.
If not I have jammed a rag in the bottom pulley/fan belt before now to help and it works to stop rotation.
Of course if you have an air gun all the better.
yatta
May 21, 2016 10:31 PM
Mark_
14
Jan 16, 2016 05:27 PM
IainRS1700T
Sep 25, 2015 06:44 AM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
