Injectors for omex 600
Old Aug 8, 2007 | 06:45 PM
GaryHurn's Avatar
GaryHurn
Default Injectors for omex 600
a few months ago i got a omex 600 ecu and loom from ross andrews who was breaking his escort zvh turbo!
the engine was sold before i had chnace to go and remove the injectors it was running! he said cossie air injectors
anyways the car was running 350+
i ve got the loom ecu but no injectors, i am wondering what impeance will i need high or low?
i am aiming for a power figure of 350bhp with my zvh motor once mapped
i have found some bosch injectors
part number :- 0280 150 588 14.5 ohm 440cc @3 bar
would these be ok
the cossie greens are
0280 150 803 370cc @ 3 bar but only 4.7 ohm
can any one help and point me in the right direction
Old Aug 8, 2007 | 07:02 PM
I would phone OMEX unless someone knows for sure(?) as the wrong ones could damage ECU, injector drivers.
As a GUESS it will be LOW impedance ones.
Old Aug 8, 2007 | 07:17 PM
GaryHurn's Avatar
GaryHurn
There are two electrical types of injector, high impedence, and low impedence. High impedence is approximately 12 ohms, and low impedence is approximately 3 ohms. The OMEM600 ECU is designed to use high impedence injectors, but can be used with low impedence if ballast resitors are used. The ballast resistors are shown in the wiring diagram.
Injectors are available in a range of flowrates. Please contact Omex for advice when selecting suitably sized injectors.
Old Aug 8, 2007 | 07:18 PM
GaryHurn's Avatar
GaryHurn
all sorted now high impedance it is
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
dombanks
Sep 21, 2015 08:38 PM
Tank Mike
Sep 14, 2015 03:56 PM
