project s1 turbo faults
just finishing off putting my s1 back together, and i've got all the bad earths at rear lights sorted and got reverse lights working, indicators, and normal red lights that come on when u put your headlights on to no 1 oe 2 position.
the only 2 sets of lights i can't get to do anything are the rear fog lights and the rear brake lights,
i presume theres no power as both light functions are just dead no brake lights or fog lights.
does anyone have a diagram or a way for me to trace the power source for the these sets of lights and to see if u a fuse or relay has blown hence why there dead to the world.
any help would be greatly appreciated peeps
cheeRS
cheeRS
You need to get a w/shop manual, all in htere.
I don't know for sure but can't see the two lights being on the same circuit.
You can easily test your brake light circuit by poking a 12v(+) feed down the wire at the pedal(switch) one will light the brake lights up, the other is the live feed to the switch.
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
Ben26
27-08-2015 08:56 PM
