capri 2.8
Old Aug 4, 2007 | 02:19 PM
bazpro's Avatar
bazpro
Default capri 2.8
i just bought a 2.8 capri and it got a bit of a running problem. it starts and drives ok but when it gets warm everytime i get 2 a junction and stop the car cuts out. the car starts afterwards but it really pissing me off any1 got any ideas wot it could be? the car has had a full service plugs leads filter dizzy cap and rotor arm and fuel filter. think it might b a fuelling problem as there is a smell of petrol when i start it.
Old Aug 4, 2007 | 03:08 PM
Have you tried raising the idle speed ?
Failing that check it is not running lean.
Old Aug 4, 2007 | 05:37 PM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
Had loads of 2.8s mate.check the breathers!
Old Aug 4, 2007 | 06:04 PM
Had a xr4i was the slowest sierra I ever had, slower than my 2.1 auto by a long way, wish I had never bought it, but did look ace.
Old Aug 5, 2007 | 10:42 AM
bazpro's Avatar
bazpro
tried raiseing the idle with the idle screw but it doesnt seem 2 make the revs pic up. thought about ajusting the mixture screw but not sure which way 2 turn it.
wheres the breathers at on a 2.8?
i know wot u mean by the 2.8 feeling slow seems quick 1 minute and slow the next i reckon my 2.0 pinto mk2 escort was quicker off the mark but the capri is so much nicer 2 drive.
started saving for some yb power now
Old Aug 5, 2007 | 11:21 AM
Screw on fuel distributor is as far as can remember clockwise to richen, but VERY sensitive, so only a little turn at a time.
Old Aug 5, 2007 | 12:22 PM
bazpro's Avatar
bazpro
cheers will try it today see if it makes a difference
Old Aug 6, 2007 | 01:20 PM
Have u been on the capri power web site i know there is a lad on there n he knows everything about capris n i mean everything.
Old Aug 6, 2007 | 04:47 PM
bazpro's Avatar
bazpro
cheers mate will have a look.
checked the plugs which have only been in a week and they where white. so that means it running lean doesnt it?
Old Aug 6, 2007 | 08:17 PM
YEP white is lean IF they are the correct heat rating plugs.
Old Aug 13, 2007 | 07:00 PM
Wardy257's Avatar
Wardy257
You cant set the idle fuel properly DIY. You need to go to a garrage so they can see the emission while adjusting it.
mk1turboestate
Dec 2, 2015 08:31 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
jonnyenglish
Sep 21, 2015 07:31 AM
STAFFY OWNER
Sep 13, 2015 08:59 PM
Adam Graham
Sep 6, 2015 06:04 AM
