Cutting off, and engine stopping on EEC IV Escos
Old Sep 27, 2004 | 10:32 PM
Azrael's Avatar
Azrael
Default Cutting off, and engine stopping on EEC IV Escos
I have had several electrilcalproblems over last few weeks. I already changed the fusebox. Acctually after that problems bicame bigger. First idiots at Fords who did the exchanged put the loom so the clutch pedal cut one of the thick rad cables nearly making car burs in flames, but just nearly. I fixed it on the roadside and car run fine. Apart from stopping somtimes. It's not connected with anything. every few hundred km's it starts to cut of, stops to react to throttle and sometimes simply dies and wont start for some time. When it happens I can hear clicking sound from the fuse/realays box. It's some relay I think. It's cutting fuel not ignition I suppose because there is no bang bang effect like when ignition problems . I know nobody who has any idea? Maybe its just some poor connection somewhere? Also a few days ago it stopped to have idle revs and made clouds of balck smoke fromm overfueling. Turning it of for like 5 mintes fixed the problem. What can that be? fucked ECU?
Tha car is small turbo + superchips and 1.5 bar boost. I never had any engine electronic problems, so I wouldn't say it's superchips module.
Old Sep 28, 2004 | 07:45 PM
AJ Escos's Avatar
AJ Escos
i would suggest taking the superchip out anyway and trying it as it sounds like the exact same problem mine had and i havent had a single problem since i removed the chip, when you say its clicking does this clicking vary in speed at all?
Old Sep 28, 2004 | 10:48 PM
Azrael's Avatar
Azrael
The car done 140 000 km's with the chip in, can it brake?
The clicking sound apears when it missfires like it was fuel pump relay or somthing.. dunno. What Ford people could fuck when changing fusebox?
I really don't want to make it slower :-(((
Old Sep 29, 2004 | 06:39 AM
Stu @ M Developments's Avatar
PassionFords Creator
Remove the chip first pal, then let us know whats happening, these modules do give trouble, especially the big heavy superchips one.
Old Sep 29, 2004 | 08:52 AM
Azrael's Avatar
Azrael
I'll try that :-/ but it does seem strange why woud it stop working only sometimes... Anyway I'll try anything. What do I change to different module?
Old Sep 29, 2004 | 04:52 PM
AJ Escos's Avatar
AJ Escos
no m8 just remove yhe chip and try it for a bit problem does sound exactly the same as mine as mine was an intermittent fault, also. edit to add listen to stu m8 as thats how i found out what was causing my problems
Old Sep 29, 2004 | 11:35 PM
Azrael's Avatar
Azrael
Today we removed ECU and superchips module. Both were covered with dust, dirty, and the contectors on both ECU multiplug and supeerchips module were less then functional. after cleaning everything very delicatly with brake cleaner the car seams to be working fine. I hope it was that. By the way - module is dark red or something and rather light"
Old Oct 2, 2004 | 11:18 AM
Old Oct 2, 2004 | 03:31 PM
Azrael's Avatar
Azrael
Thanks for suggestions. After repair I was able to do some nice driving - if you want to see it photographic and video documentation will soon be here:
http://foto.luftbrandzlung.org/SJS
Thanks
Old Oct 2, 2004 | 04:44 PM
Dave Henshall's Avatar
Dave Henshall
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
mattman1234
24
Aug 1, 2015 11:46 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
