rs turbo fueling problem.
Old Jul 28, 2007 | 01:05 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default rs turbo fueling problem.
im running a standard mfi rs turbo fuel pump and im getting 2.5 litres of fuel through it every minute.taking the measurement from the rail.is 2.5 litres a minute about right because ive been told it should be around 3 to 3 and a half.any ideas???thanks
Old Jul 29, 2007 | 10:04 PM
davidreader5's Avatar
davidreader5
If your talking about the operation of the fuel pump by a measurement of fuel , a fuel delivery check under pressure, at the return connection of the fuel regulater ERST,mfi at the return connection of the regulator undo this connection make up your own return pipe and put into a container run the pump, for 1,min, minimum delivery 1100 cm3/min, or half that if you run your stop watch for 30,seconds, you can make the pump run by a bridged wire fused connector to pins, 87 & 30,,
Regards Dave R. MotorVation RS.
Old Jul 29, 2007 | 10:50 PM
zvhturbo29rs
Default fueling problem
hi mate sent you a pm for abit more advice.thanks alot
Matt Baxter
Sep 16, 2015 08:30 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Bailes1992
Aug 16, 2015 07:14 PM
taylora1409
Aug 12, 2015 12:06 PM
