Koni Yellow adjustable shocks
Old Sep 27, 2004 | 12:31 AM
SS1's Avatar
SS1
Default Koni Yellow adjustable shocks
got them on a sierra Sapphire set on hard
car is very low.. front arches rolled back to
use 17inch momos but rides like a gocart
if i turned down the settings on the front
dampers ie shocks..?? would the front wheels
bounce any higher when hitting pot holes
its got 205,45,17s on it
would the tyre hit the inner wing
on a softer setting tooth filling shaker
any help would be cool
Old Sep 27, 2004 | 08:38 PM
richm's Avatar
richm
the adjustment is mainly on the rebound rate, the bump rate stays essentially the same, so the bump behaviour is unlikely to be much different if you turn them softer.
Nov 1, 2015 06:53 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
