temp reading
Old Jul 24, 2007 | 06:46 PM
tob4x4's Avatar
tob4x4
Default temp reading
where on a saph cosworth 4x4 should the temp reading be mine is over half way but does not go beyond the o in norm i hate cars my 2wd used to sit at just above the m whats the crack also with it running hot do you thibk a new thermostat and a engine flush may help cheers
Old Jul 24, 2007 | 07:39 PM
Do the fans come on when it gets too hot ?, does it bring the temperature down ?
If it does both of these it is fine, mine goes into the O before the fans come on and takes a while for it to come down but never overheats.
Mine is a 2wd but same thing, but 4wd cooling system is better as well.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Iain Mac
Sep 30, 2015 09:39 PM
