running on two cylinders
Old Jul 23, 2007 | 10:44 PM
mk1mad's Avatar
mk1mad
Default running on two cylinders
My mate's got a 99 Ka 1300, it's only firing on cylinder's 2&3 any ideas or has anyone came across this fault before?
I suspected a sensor fault so "borrowed" a crank & camshaft sensors & coil from another Ka and it has made no difference.
It's almost as if the car's in limp home mode but correct me if I'm wrong they don't have this feature do they?
Possible wiring/ecu fault?
Any links to wiring diagrams or any readings i should be looking for?
Thanks in advance for any help/advice given!!
Old Jul 24, 2007 | 04:19 AM
LOS, or LIMITED OPERATION STRATEGY will NOT be like this it will just be flat, it does NOT cut cylinders out.
I doubt very much it is running on two cylinders, if a sensor was buggered it would affect all the cylinders.
The coil or it's wiring is the most likely cause as the baddy.
I would think it will definitely have a LOS mode as it has CAT.
Does it have a exhaust gas pressure differential sensor ?, as this will make it go absolutely flat.
Old Jul 24, 2007 | 12:26 PM
SafeChav's Avatar
SafeChav
is it running a coil pack?
Chances are thats gone, seeing as 1&4 fire at the same time, as do 2&3
Check for a spark
Old Jul 24, 2007 | 01:06 PM
mk1mad's Avatar
mk1mad
cheers folks, when i said firing I meant sparking!! Yeah it's got a coil pack, I tried another one on but I don't know if that coil was good as it was from a breakers, it was exactly the same.
What do you mea by a exhaust gas pressure thingy? A lambda sensor? if so it has!!
I'm going to try a different coil on it tionight then get an auto electricaian to have a look if that does'nt sort it!
Old Jul 24, 2007 | 01:28 PM
SafeChav's Avatar
SafeChav
Chances of getting 2 coil packs with the same fault are slim
Resistance test the primary and secondary coils.
You could have a wiring fault if its not the coil then, can't see it being much else
Old Jul 24, 2007 | 03:25 PM
mk1mad's Avatar
mk1mad
any idea what sort of resistance i shoulkd be looking for mate~? Or will i just test it and if they aint too far apart assume the coil's good? I think i'm just going to get the sparky to sort it as my assumpution was the same as yours that it's highly unlikekly to have two coils with the same fault!
Old Jul 24, 2007 | 08:46 PM
SafeChav's Avatar
SafeChav
not off the top of my head, but you should be able to tell if the range you use isn't high enough.
Old Jul 26, 2007 | 12:43 PM
mk1mad's Avatar
mk1mad
Turns out the ecu's fooked, they reckon the coil's shorted out and blown a circuit.
I can get an ecu, transponder and key from the breaker's pretty cheap, is it just a case of swapping them over? will it work if i swap them straight over or does anything else have to be done?
Any help/ advice greatly appreciated
Old Jul 26, 2007 | 01:16 PM
SafeChav's Avatar
SafeChav
replied to your PM mate
Old Jul 27, 2007 | 07:22 AM
Wardy257's Avatar
Wardy257
The coil can not really short out and affect the ECU. Have you tested the coilpack conector with a Noid light? What did the garage actually test?
Old Jul 29, 2007 | 08:42 PM
mk1mad's Avatar
mk1mad
it was the ecu that was fooked, the circuit that controls the spark for cyl's 1 & 4 was burnt out, don't know how it happened though.
Ecu from scrappies fitted with transponder & chip running well now
Thanks for your help folks
dombanks
Sep 21, 2015 08:38 PM
Eigdoog
Sep 13, 2015 05:46 AM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
cossirob
Sep 3, 2015 09:17 PM
