Any one got a small turbo esc cos
Only need a kind person to look under the bonnet of there car and tell me where a small rubber hose connects to it is the one that goes from a small conical unit that sits beside the map sensor on the nearside inner wing the unit has wires underneath and a rubber pipe going in and a pipe coming out many thanks
sounds like you mean the carbon canister solenoid,this goes from the carbon canister ppipe to the inlet manifold,it should have a non ret valve between the solenoid and manifold,it connects on a t piece on the back of the inlet manifold about halfway along its length
steerfromdarear
28
29-01-2016 06:14 PM
Matt Baxter
16-09-2015 08:30 PM
