escort mk5 heater not working
Old Jul 20, 2007 | 07:27 PM
shaw109's Avatar
shaw109
Default escort mk5 heater not working
Hi all please can you help me i hav a mk5 escort 1.3 and the heater has stoped working i have checked the fuse and its ok and also changed ehe heater switch in the car but nothing ,i have also ran a wire from the pos side of the battery to the heater blower and touched the three point conector on the top and the blower works fine has anyone got any other ideas on what it could be many thanks to all of you shaw109
Old Jul 21, 2007 | 01:10 AM
gup's Avatar
gup
sounds like the heater resister has failed fella but when these go they normally only give you the full speed setting
Old Jul 21, 2007 | 01:44 PM
Aaroncast's Avatar
Aaroncast
hope for nice weather
Old Jul 21, 2007 | 03:04 PM
shaw109's Avatar
shaw109
Hi qup thanks for that i will have to go and check it again if it is that is it just a case of changing the hole fan or just the risistor its a pain the bum anyway you look at it anyway thanks again shaw109
p.s Hi Aaroncast i hope for nice weather every day mate? thanks for the reply al the same.
Old Jul 21, 2007 | 03:08 PM
gup's Avatar
gup
just change the resister fella
have you got power at the back of the fan switch tho fella
Old Jul 21, 2007 | 03:25 PM
shaw109's Avatar
shaw109
hi there just checked fan works fine on 1,2,3, when testing with the wire have a volt meter so will check that now got any idea what it should be mate
Old Jul 21, 2007 | 03:46 PM
shaw109's Avatar
shaw109
Hi just to let you know i have tested the heater switch behine the dash and there is a good reading of 10.55 volts so am i right in thinking that it must be a short some wear or wolud that blow the fuse as the fuse is fine am lost with this one can sort most things myself but this has got me beat many thanks shaw109
Old Jul 21, 2007 | 04:38 PM
shaw109's Avatar
shaw109
hi all come on guys still need help withe this this is what i have tested 10.55 volts at the switch in the dash 10/11 volts at the main fuse box but only 5/6 volts at the multy plug on the top of the blower this seams low to me or is it wright ??? come on lads help me out this is driving me mad
Old Jul 21, 2007 | 10:22 PM
zetecturbo's Avatar
zetecturbo
ur fusebox is gone mate.the mk5 fuseboxes are renowned for this ,the solder track inside the fusebox goes dry and u then lose continuity.thats y no fuses are blown and the heater will work with a live from the battery ,.my suggestion for a quick fix would b to wire up a relayed live feed from the battery connected to the ignition switch so that it will only work when u switch on the ignition as normal
Old Jul 22, 2007 | 09:28 AM
shaw109's Avatar
shaw109
Hi Zetecturbo i have just fond out after going to hit the horn that the sound is very weak it is hardley working would this go along with the fuse box going like u said checked the feed wire and i only have 5/6 volts going to that two but again have 10/11 volts at the fuse box???
Old Jul 22, 2007 | 12:31 PM
shaw109's Avatar
shaw109
HI all ref horn now fixed bad earth cleaned up and works great ,but still not sorted the heater out. Zetecturbo i have checked the fuse box there is a good reading coming from there of 10/11 volts would the fuse box still be to blame for this?? thanks for all the help but still need more
Old Jul 22, 2007 | 03:08 PM
Dave Parker's Avatar
Dave Parker
heater is always the first to go when fuse box fails
https://passionford.com/forum/viewto...light=#3952443
Old Jul 22, 2007 | 04:31 PM
zetecturbo's Avatar
zetecturbo
hi mate the dry solder on the printed circuit board in the fusebox causes an intermittent fault thats y sometimes it mite work and then wont ,i guarantee ya mate its the fusebox is the cause
Old Jul 23, 2007 | 04:43 PM
shaw109's Avatar
shaw109
Hi all
Just to let you know had to go for the easy fix and have now wired it up to work from the live feed from the battery connected to the ignition switch so that it will only work when u switch on the ignition as normal not what i had planned to do but it will do untill i can get the fuse box sorted many thanks to all of you that help me with this shaw109
Old Jul 25, 2007 | 07:48 PM
SafeChav's Avatar
SafeChav
Fuse box as said.
Its all very well running reverse feeds, but when other things fail they will start back feeding off your bodged in wire, and theres the potential fot overload/fires to happen!
Just thought i would warn you......
Old Jul 30, 2007 | 06:23 PM
shaw109's Avatar
shaw109
Hi safechav thanks for that will be getting fuse box in next few days so will let you know if it sorts out the problem many thanks
Old Jul 30, 2007 | 08:14 PM
SafeChav's Avatar
SafeChav
If your thinkin of fitting a second hand box i wouldnt bother mate its more than likely going to be fucked aswell.
Old Aug 1, 2007 | 12:48 PM
shaw109's Avatar
shaw109
Hi safechav no mate had to order new one arriving on friday i hope it is the fuse box cos it was not cheap but the more i think of it the more it makes sence will let you know what happens when i fit it thanks again shaw109
Old Aug 1, 2007 | 11:20 PM
SafeChav's Avatar
SafeChav
how much did that set you back
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
