4x4 missfire
Old Jul 19, 2007 | 01:32 PM
w33bob's Avatar
w33bob
Default 4x4 missfire
Hi guys, I was hoping some of you could offer me a bit of advice on a wee problem I'm having with my sierra. I bought it recently, my first ford and first turbo car so any advice would be appreciated.
Heres the engine spec:
T35/-63 with -34 actuator
3 bar map
AH RS500 type intercooler
Grey injectors
Stage 4 chip with closed loop conversion
Cometic multi layer headgasket
Group A Coil
Uprated plugs
Group A Fuel pump
Roose hoses
Induction kit
Spec r breather system
Car drives and goes perfect until it's driven around town or anywhere at a v.slow speed, it then starts to miss and splutter. As soon as its taken back up to a decent speed though with plenty of air flow it clears itself out and runs fine again. I just replaced the distributor cap and rotary arm as I thought this may be the cause of it but the missfire continues. Any thoughts?
Bob
Old Jul 19, 2007 | 06:23 PM
jon@work's Avatar
jon@work
have you tried a different set of spark plugs ?
popular cheap ones that people use for this spec would be Ford 071's (finis code 1120834) (about £12 a set)
Old Jul 21, 2007 | 09:40 AM
330bhpcoz's Avatar
330bhpcoz
try phase sensor in dizzy happend to me
Old Jul 22, 2007 | 10:46 PM
w33bob's Avatar
w33bob
Cheers guys, had a set of plugs en route so i'll try the phase sensor too.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
