Clinder head rebuild
Old Jul 19, 2007 | 01:03 PM
mk4gartrac's Avatar
mk4gartrac
Default Clinder head rebuild
Should i use any sealer on any gaskets when rebuilding my cylinderhead if so what and where?
Old Jul 19, 2007 | 03:08 PM
jon@work's Avatar
jon@work
the only sealer I use is on thermostat housing, water pump, and sump - blue hylomar
Old Jul 20, 2007 | 07:50 AM
Thermo housing unless you use a reusable cometic, water pump sump plug and half moons, also under cam caps(front) as they will leak here otherwise.
Even ford say use it there!!
Old Jul 20, 2007 | 10:18 AM
SafeChav's Avatar
SafeChav
Oh really?
You sure you don't mean you know some chimps that work for Ford and they said to use it?!
What would be the point in a gasket if they advised using sealant? Nissans for example are known for using sealant on sumps, but theres no gasket on them.
Usually one or the other.
Old Jul 20, 2007 | 11:21 AM
mk4gartrac's Avatar
mk4gartrac
What sealer is used on the half moons and front cam caps?
Old Jul 20, 2007 | 11:35 AM
davsmith64's Avatar
davsmith64
i used it on all my gaskets BUT DEFFO NOT ON THE HEADGASKET!!! wouldnt use it on the rockercover gasket either
i used some loctite stuff.. good stuff imo..
i would advise to use it on the sump also.. but i would say that cos ive experienced my sump leaking..lol
Old Jul 20, 2007 | 02:26 PM
Try as I might I cannot find where I have said use sealant instead of a gasket.
If the right sealant is used it can replace most gasket though, ie sumps, water pump, thermo, housing, rocker cover, it is, or can be more modulous than a rigid gasket.
Old Jul 20, 2007 | 02:51 PM
mk4gartrac's Avatar
mk4gartrac
What about the inlet manifold?
Old Jul 20, 2007 | 03:09 PM
mk4gartrac's Avatar
mk4gartrac
should there be a gasket between the turbo and manifold?
Old Jul 20, 2007 | 04:51 PM
SafeChav's Avatar
SafeChav
Tabetha i swear you are on a different planet sometimes.
The point i am demonstrating:
Some manufacturers use gaskets.
Some manufacturers use sealant.
rare is the day they use BOTH.
old Fords use gaskets, NOT sealant?
Old Jul 20, 2007 | 06:06 PM
Whether ford or anybody else use gaskets or sealants on their own is not the issue it is what actually works in the real world.
Most, if not everybody, has had leaks with what the manufacturere used, so use sealants to help.
Old Jul 21, 2007 | 02:23 PM
messcortmk6's Avatar
messcortmk6
ffs stop arguing about gaskets and seelants, the reason for the gasket is to make a seal so seelans is not necessary if there is gasket, also modern gaskets have multiple layers and mould just fine.
NO NEED FOR BODGE SEELANT!!! IF YOUR GOING TO USE SEELANT JUST USE DUCT TAPE FOR GASKETS IN THE FUTURE.
Old Jul 22, 2007 | 04:06 PM
mk4gartrac's Avatar
mk4gartrac
Old Jul 22, 2007 | 05:51 PM
jon@work's Avatar
jon@work
blue hylomar will be fine
Old Jul 22, 2007 | 10:35 PM
mk4gartrac's Avatar
mk4gartrac
Thank you
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
