can this cvh head be repaired or is it scrap
Old Jul 13, 2007 | 06:04 PM
base190380's Avatar
base190380
Default can this cvh head be repaired or is it scrap
hello everyone, i was degreasing and pressure washing a replacement cvh head for my engine when i noticed that the face of the head has broken where the water passes through. it has not broke through to the piston chamber although it is close maybe 2mm away. can a cylinder head shop do a repair on this? i am worried that if i fit it it may leak water into the 3rd chamber. cheers guys.
Old Jul 13, 2007 | 07:04 PM
Easy repair, but might be cheaper getting another head.
Old Jul 13, 2007 | 08:14 PM
base190380's Avatar
base190380
cheers thanks, what should i ask for when taking it to get repaired. does it get welded or somthing?
Old Jul 14, 2007 | 02:05 AM
SafeChav's Avatar
SafeChav
I think the deciding factor on that needs to depend on how many times has that head been skimmed?
If its had a fair few skims you'd be better of getting a head off a low mileage/unmodified car.
Unless of course its had lots of port/polishing work done..........
155lee
Sep 6, 2016 11:10 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
rsguy
44
Sep 29, 2015 03:29 PM
sridgett
13
Sep 27, 2015 06:03 PM
Russp
Escort Range
Sep 18, 2015 07:39 PM
