CVH problems
Old 25-09-2004, 04:12 AM
turborules
turborules's Avatar
Default CVH problems
Hello.Can i put a CVH head in to 1600 Zetec block.Dos anyone know 1600 Zetec bore x stroke.Is the Zetec block stronger than CVH.What about the crankshaft.Is the RS turbo block/crank/head the same as normal 1600i.Does all hemi CVH have the same head?
Old 25-09-2004, 09:21 PM
b13nde
b13nde's Avatar
you need to mod the head if your gonna start doing that then you mite as well go for the 2.0ltr bottom end its a waste with the 1.6
Old 26-09-2004, 08:17 AM
turborules
turborules's Avatar
Default Rules,rules
Hello.Its gonna be a race engine and 1600cc 8v is for class min.weight rules.There isnt gonna be any org. parts on the engine exept block,crank and cvh head! What is the bore x stroke on a 1600 Zetec? Are all CVH open chamber heads the same?
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
DAZZER
30-09-2015 08:43 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: CVH problems
