need your help guys please
Old Jul 8, 2007 | 04:13 PM
pingu's Avatar
pingu
Default need your help guys please
hi i recantly put a rs turbo engine in my xr3 cabby problem is i have never had it running yet but there is no power going to the distrbuter plug the auto lekky did something with the fuel ecu he said he was testing it continuely or something and said it was that.it did used to have power to it so i have had 3 fuel ecu's all now all of them dont work coz i dont get ne power to the dizzy is something blowing them and wot could it be help please
Old Jul 8, 2007 | 07:38 PM
SafeChav's Avatar
SafeChav
The power to the coil is an unfused ignition supply so i can only assume you have an internal loom fault......
Old Jul 10, 2007 | 09:45 PM
pingu's Avatar
pingu
wot does that mean then mate i but a blub from the power lead and the earth lead that goes to the coil but it did not light up when the ignition was on also is it the black ecu which controls the power to the coil (fuel ecu) is it coz i notice both ecus plug into the same plugs one conector says amp on it so dos the fuel ecu go into that one mate
Old Jul 10, 2007 | 11:11 PM
SafeChav's Avatar
SafeChav
The power to the coil is unfused - no fuse in its circuit so if theres no power there then theres a loom fault somewhere!
The bulb wont light up with the ignition on, it should flash quickly when you crank the engine.
Silver ecu controls the coil, the ecu plugs are completely different, and so are the latches on them
Old Jul 11, 2007 | 10:53 AM
Barry R's Avatar
Barry R
mine was like this identical problem turned out to be the brown earth wire by the wiper motor try it
Old Jul 11, 2007 | 07:41 PM
pingu's Avatar
pingu
barry was the earth wire not earthed right you mean mate also for some reason sometimes everything that works the on the igntion live just starts going even when the keys arnt in the car
Old Jul 11, 2007 | 07:57 PM
pingu's Avatar
pingu
lol right i also had the ecus the wrong way round is it possile that i have now blown the ecus i have power going to the hall i think its called the plug that goes into the thing on the dizzy which i never had before i have a power going to the coil but when i plug it into the coil it makes both outer pins posative the earth from the coil to the ecu i put the bulb to the posative on the battary and one to the earth on the coil wire and it did not light up ne thoughts mate
Old Jul 11, 2007 | 09:15 PM
Barry R's Avatar
Barry R
mine was the same and like i said all it was
was the brown wire not earthed good enough
i redone it now every things fine
Old Jul 11, 2007 | 09:34 PM
105epwr's Avatar
105epwr
ive just put a rst motor in a mk3 cab if you completly stuck get your self a haynes manual and check out the wiring diagrams!
Old Jul 12, 2007 | 11:25 AM
SafeChav's Avatar
SafeChav
Mate i said above the bulb won't light across the coil unless you crank it, the negative switches to fire the coil, so putting a bulb on it just with the ignition on will never light up.........
Old Jul 12, 2007 | 05:54 PM
pingu's Avatar
pingu
so the coil pins both been live is ok and also could i have do some damaged to the ecus then mate
Old Jul 13, 2007 | 12:47 PM
SafeChav's Avatar
SafeChav
What your tellin me you've got 12v on the green wire when you put a meter across that and earth?
Old Jul 13, 2007 | 10:32 PM
pingu's Avatar
pingu
yes mate i noticed the earth wire on the ecu the conector is bent quite wide so might not be touching could that be it
Old Jul 14, 2007 | 01:59 AM
SafeChav's Avatar
SafeChav
still don't see how you're getting 12v on there but yea i would sort the damaged pins out so you can eliminate that from the equation.
OrionRST200bhp
Sep 29, 2015 08:30 PM
Fiddy
21
Sep 29, 2015 06:10 PM
`spotty
Sep 25, 2015 11:41 PM
davidfordrs
Sep 21, 2015 04:23 AM
Rizlablue
Sep 6, 2015 09:58 AM
