injector loom
Old Jul 3, 2007 | 10:50 PM
bankyg60's Avatar
bankyg60
Default injector loom
hi there i have a 4x4 sapphire cosworth and i have no power going to the injectors so thay are not fireing is there a fuse sum were .i have checked the wireing that is all fine ????please help
Old Jul 4, 2007 | 06:38 AM
You need to check the power at the ecu and the relay that feeds it.
Old Jul 4, 2007 | 08:18 AM
bankyg60's Avatar
bankyg60
ok will look at it 2night many thanks
Old Jul 4, 2007 | 08:34 AM
I'm just waiting for some good (dry) weather so I can look at my car!!
Old Jul 4, 2007 | 02:46 PM
velocity's Avatar
velocity
check that fuse 41 is not blown, as this fuse is the feed supply to the fuel injection relay
the fuel injection relay also powers the fuel pump relay so the fuel pump will not operate without the fuel injection relay working.
next is the 6 pin rectangle block connector on the bulkhead ,the red wire is the injector supply to all four injectors, check for power at this point. you should also have power at pin 20 on the ecu block connector.
the fuel injection relay if my diagrams and memory are correct is located on the relay bank holder under the dash on the l/h side behind the glove box which you simply grasp an pull sharply out of its pivots.
its designation is P2.
terminal wireing is
86------------black (ignition switch supply)
85------------blue & green (earth through pin 10 on ecu)
87------------red ( to the fuel injectors) also blue and black ( to the fuel pump relay)
30-----------red & white (supply for injectors and fuel pump relay from fuse 41)
good hunting
Old Jul 4, 2007 | 09:00 PM
bankyg60's Avatar
bankyg60
will look at that in the morning many thanks .fingers crossed .
Old Jul 16, 2007 | 07:15 AM
bankyg60's Avatar
bankyg60
still wont start guna send my e.c.u off for testing i had my phase senser on the rong way hope i havent f***ed it up .........
Old Jul 16, 2007 | 09:35 AM
jon@work's Avatar
jon@work
fitting the phase sensor the wrong way will not affect the ECU
don't bother sending off your ECU if you haven't got 12V at the injectors - check out the fuses/relays first - the ECU switches the earths for the injectors, which should have 12V to them all the time with the ignition on
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
muz
Sep 30, 2015 08:29 AM
