compression test??
Old Jul 1, 2007 | 03:35 PM
rsgav83's Avatar
rsgav83
Default compression test??
Hi everyone what sort of compression reading should i be getting out of a s2 erst?
As i done one the other day just out of interst and all the cylinders read about 125 on each one is this ok??
Old Jul 1, 2007 | 10:31 PM
juffer's Avatar
juffer
mine read about 115-120 so it cant be to bad i dont know what ford recommend tho
Old Jul 5, 2007 | 04:07 PM
messcortmk6's Avatar
messcortmk6
yes it is fine, nothing to worry about there, whydo you think there is a problem or were you just asking if it were okay?
Old Jul 5, 2007 | 09:13 PM
rsgav83's Avatar
rsgav83
Someone told me to do a compression test due to when cold starting it takes a long time to fire up and misfires for a bit but have now sorted it by unplugging the cold start injector fires up fine now
And was just wondering if the readings i got on compression test where ok!
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
