low comp pistons
Old Jun 27, 2007 | 06:06 AM
sy.rst's Avatar
sy.rst
Default low comp pistons
im thinking bout buying a set of low comp pistons for my series 2 rs turbo,i have got a stage 2 turbo kent cam,grs intercooler im only running 15psi at the mo coz havent had it set up, would it be worth me fitting sum low comp pistons,i dont want 2 run massive boost coz need it 2 be reliable coz its my every day car proberly turn it up to about 18psi at the most.dont wana push my stadard pistons to the limit.
Old Jun 27, 2007 | 04:58 PM
homer j's Avatar
homer j
if the standard pistons are in good nick they'll easily handle 18 psi matey. i wouldn't lower the comp ratio on that boost level myself as you'll only end up losing the lower end torque making it crappy off boost. if you wanna fit forged pistons for peace of mind then get some that retain the standard comp ratio of 8.2:1.
cheeRS
tom
Old Jun 29, 2007 | 04:54 AM
rs_cabby's Avatar
rs_cabby
as above mate, definately no point in fitting low comp pistons if you are not planning on running silly amounts of boost. i looked into this when i rebuilt mine and was told not too, as homer j said you will loose a small amount of power if you were to run the same boost you currently run,
in the end i went for forged pistons using the same compression ratio and
im glad i did as my car seems to have slightly more power than alot of people running similar boost with low comp pistons and more aggressive cams and turbos.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
Tank Mike
Sep 26, 2015 08:07 AM
