Electrical problems on mk4 escort rs turbo
First problem was drivers window would not close. Now window works again.
When i lock drivers door with central locking system, car unlocks & locks again. If i open drivers door during this problem then locking system keeps tripping all the time until i disconnect battery. I have fixed broken brown wire in drivers door. I have checked all connections at both doors and cleaned with wd40.
Anyone experience any similar problems.
You sure there is no broken wires in the flexible wiring sections which run from the car body to the door!
Very common, and hard to track down sometimes being an intermittent fault.
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
