frst won't start help!!!!!!!
Old Sep 23, 2004 | 12:58 AM
murfs frst's Avatar
murfs frst
Default frst won't start help!!!!!!!
I started my car a couple of days ago it ran for about 1 minute then just cut out.now when i turn on the ignition you cant hear the fuel pump.I have checked the fuses,relays and the multi plug on the fuel pump ime running out of ideas.would the fuel pump just pack up like that any help would be greatful cheeRS
Old Sep 23, 2004 | 10:09 AM
ASHCOSSIE's Avatar
ASHCOSSIE
have u got a feed at the pump
Old Sep 23, 2004 | 12:45 PM
murfs frst's Avatar
murfs frst
did not check have no test light.but if there is no power or i have power what do you think it could be cheeRS.
Old Sep 23, 2004 | 01:07 PM
ASHCOSSIE's Avatar
ASHCOSSIE
if u have power then proboly pump,but i think the pump is in the tank on that one,i think u can get to the wires under the back seats
Old Sep 23, 2004 | 05:09 PM
murfs frst's Avatar
murfs frst
ok cheers mate
Old Sep 23, 2004 | 07:13 PM
oriont's Avatar
oriont
if your getting fuel check the pressure as it could be the diaprham unit after the pump has split. when it does you get fuel to engine but not enuf pressure.
failing that are you getting a spark??
if not check the CPS (crank) sensor.
hth's
thanks
oriont
Old Sep 23, 2004 | 09:34 PM
murfs frst's Avatar
murfs frst
will do cheers mate
Old Sep 25, 2004 | 01:12 AM
murfs frst's Avatar
murfs frst
i have a feed going to the fuel pump so i guess it must be the pump then yes or no!!!!!!
Old Sep 25, 2004 | 08:02 AM
cozzymatt's Avatar
cozzymatt
try the pump cut off switch first (passenger footwell). Then check the crank position sensor! if you order a new one ensure that you order the correct one because there are 2 different lengths and i had a right ball ache trying to sort out my old fezz..
good luck..
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
Bailes1992
Sep 3, 2015 02:17 PM
kevin36
Sep 2, 2015 06:24 PM
