Cosworth Cam Timing
Old Sep 21, 2004 | 03:28 PM
CosRush's Avatar
CosRush
Default Cosworth Cam Timing
Ensure Cam sprockets are aligned.
Ensure Crank Pulley is aligned to the TDC Peg.
Ensure Auxilary Pulley Pointer is central to the Half Circle.
It all should like this.
Belt tensioner
Belt tension
Old Oct 1, 2004 | 03:00 PM
Dave Henshall's Avatar
Dave Henshall
just to add, as a rule of thumb, in the longest run of belt.. there should be just enough tension in it to be able to twist the belt through roughly 90 degrees. as a final check wind the engine round twice on the bottom bulley with the plus out and check the alignment of all the above points again
Old Oct 1, 2004 | 03:11 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Don't you have to feed the belt round the pulleys anticlockwise too ? Starting at the crankshaft ?
Cosrush, these are superb pictures, about time we got something better than ford's low res diagrams
You might just have saved a few peeps some valves, etc...
Old Oct 1, 2004 | 03:12 PM
frog's Avatar
frog
Edited to say that if the above is wrong I will take it out before someone gets in trouble on my account
Old Oct 1, 2004 | 03:15 PM
CosRush's Avatar
CosRush
Thanks
I took them before i dismantled mine, and thought others could benefit from them...
Old Oct 1, 2004 | 03:19 PM
CosRush's Avatar
CosRush
By the way...
Those pictures were taken in my old kitchen where i dismantled it
My wife didn't mind though
Old Oct 1, 2004 | 03:41 PM
Dave Henshall
and if u notice , ever so slightly the left hand cam pulley is just out of plonk a smidgin - this is what justifies the need to vernier timing pulleys, if you are running a wild cam and it was out by that very small amount , you could end up with bent valves. on a std engine with std cams the EXACT mechanical timing is not quite so crutial.
Old Dec 15, 2004 | 09:26 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i have a couple of points toadd, based on experience.
1) the crank pulley should be lined up so that the leading edge of the square peg is in line with the blade of the timing marker, rather than the centre of it as pictured (according to the YB service manual).
2) tensioner. the manual says to tension the belt by turning the tensioner clockwise and locking it. if you do this, the belt is trying to turn the tensioner anticlockwise which has a loosening action against the locknut. i had this happen that the locknut loosened and the cambelt loosened and jumped and fucked all 16 valves.
if you tension the belt by rotating the tensioner anti-clockwise, the belt pushes against it and keeps it tight against the locknut.
Old Dec 15, 2004 | 09:38 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i've re-read the manual, and point 1 is described as the 'flank of the tooth', whatever that means.
Old Dec 15, 2004 | 09:57 AM
foreigneRS's Avatar
foreigneRS
Testing the future
from doing a google, the 'flank of the tooth' would seem to be the leading edge, rather than the flat top.
Old Jan 11, 2005 | 09:51 PM
Graceland's Avatar
Graceland
Team HOTHOT!
is this the same for a greentop 4x4 saff engine then (200 block) ?
Old Jan 17, 2005 | 11:49 AM
Stu @ M Developments's Avatar
PassionFords Creator
Couple of points to add:
1) Trailing edge is the correct TDC point.
2) The tensioner MUST be done clockwise to centralise the belt in the runners.
Old Jan 17, 2005 | 06:51 PM
CosRush's Avatar
CosRush
Ive edited these pictures a little.
Hope this is an improvement, and clears up any ambiguity
***these have now been amended at the top of tis post***
Old Jan 17, 2005 | 09:25 PM
richm's Avatar
richm
and if you try to tension it anticlockwise, the belt rubs on the thermostat housing
Old Jan 17, 2005 | 09:30 PM
CosRush,
Nice edited pics.. very clear indeed
Old Jan 19, 2005 | 09:30 AM
Neil S's Avatar
Neil S
Would anyone mind if I add my two pence worth?
Don't assume that if the Aux Drive pulley is aligned as shown that the dizzy will be aligned correctly - Take the dizzy cap and shield off, put the rotor back on and align the centre of the rotor contact with the mark on the rim of the dizzy
Neil.
Old Jan 26, 2005 | 02:17 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i don't understand what you mean Stu. Do you mean where the belt comes out of the front cover near the crankshaft pulley?
i've got my tensioner done up anticlockwise, and the belt does not contact either the front cover or anywhere near the thermostat housing. but you've got me worried now. but i really don't want to change it as to me it's risky when it's clockwise and trying to undo it's locknut. i know that's how ford and cosworth say it should be done and that's how thousands are running.
CosRush, great pics. has clarified the crankshaft tooth position brilliantly as well.
Old Jan 26, 2005 | 02:33 PM
richm's Avatar
richm
Personally, I too agree with your reasoning, and I deliberately tried to tension mine anticlockwise when I last changed the belt, to see how it would fit, and the belt rubbed firmly on the thermostat housing flange/bolt in that position... (mine is 4x4 if it makes a difference to the thermo housing..)
Old Jan 26, 2005 | 02:43 PM
CosRush's Avatar
CosRush
Thanks for the comments on my pics....
If they help anybody then thats got to be good
Old Jan 30, 2005 | 04:23 PM
foreigneRS's Avatar
foreigneRS
Testing the future
yes it does rich, well they're different parts anyway, so they could well be differently shaped in that area.
Old Jan 6, 2006 | 05:59 PM
For anyone on verniers tha arent clear on where the pulleys should line up or might have been apart and put back wrong, the woodruff key is opposite the triangle, so starting point should be the two woodruff keys facing away from each other (ie the opposite way to the triangles, so facing apart not facing together)
Old Mar 26, 2006 | 08:15 PM
CosKev3's Avatar
CosKev3
Great thread
I am tackling my belt/tensioner this week
Thanks
Old Apr 12, 2006 | 12:45 PM
bud-weis's Avatar
bud-weis
Football Cwazy
good point
on kent verniers, the word 'cams' is in the position where the arrows would be,like this ( kinda hard to see sorry )
http://img.photobucket.com/albums/v2...s/IMG_3811.jpg
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
Aug 14, 2015 07:29 AM
taylora1409
Aug 12, 2015 12:06 PM
