Leaking petrol tank
Old Sep 20, 2004 | 07:49 PM
Paulr's Avatar
Paulr
Default Leaking petrol tank
Hi all.
Have the most tinyiest of petrol leaks from my tank in my erst around where the fuel pump pipe joins the tank, i have renewed the fuel pipe but the leak is still there. I have now discovered where the leak is on the tank, but was just wondering what i could use to seal the area where the leak is e.g some resin in a tube or something similar. any ideas?
Paul
Old Sep 21, 2004 | 09:42 AM
ASHCOSSIE's Avatar
ASHCOSSIE
A NEW TANKS ABOUT 50N QUID MATE AND TAKE ABOUT AN HOUR TO FIT YOUR MUCH BETTER JUST DOING THAT , I HAD THE SAME PROBLEM ON MY OLD ONE .
Old Sep 22, 2004 | 04:21 PM
adamS2RST's Avatar
adamS2RST
IS it definately the tank that is knackered?
Old Sep 22, 2004 | 05:58 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Sounds like the weld has cracked
Old Sep 22, 2004 | 06:24 PM
SS1's Avatar
SS1
they go on the seam weld ..dont botch it up mate
change asap.. its a standard ford factory fault ..welds where
s**t on the seam welds just keep tank empty as possible
to you can get a new one + spare red container full of a
fivers juice case you run out.. .. this happend to me
on a sapphire and a s2rs turbo ..s**t happens
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
