Turbosmart E-boost control problem
Old May 20, 2007 | 09:13 PM
lordb9's Avatar
lordb9
Default Turbosmart E-boost control problem
I am new to this forum - I run a Westfield with a fully standard 2wd Cosworth (turbo) and last year I had one of these e-boost controllers fitted.
I've started to play with the settings and I'm not having much fun. The car seems to run best with standard wastegate min boost ( approx 7psi). When I try to run anything higher the engine starts to miss at about 4500 (almost as if the rev limiter has kicked in, I'm short shifting all the time to to keep moving.
I've fitted a new (stndrd 2wd cosworth) fuel pump so Im pretty sure its not that.
Has anyone had any experience of setting the Set Points, Gate Pressures and Sensitivities to any better success.
I'm going to have to go to my local rolling road guys but I dont think they've had the experience on these.
Any advice or pointers welcome.
Thanks
R
Old May 21, 2007 | 10:16 PM
ajjames's Avatar
ajjames
sounds like your car is not chipped so its hitting the over boost i have got that boost controller fitted in my escort cos small turbo
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
dombanks
Sep 21, 2015 08:38 PM
markk
Sep 9, 2015 08:11 AM
routemaster
Sep 7, 2015 05:27 PM
