rear poly bushes saff cosworth
Old 15-05-2007 | 09:30 PM
madmurdy's Avatar
madmurdy
Default rear poly bushes saff cosworth
hello i have just fitted some rear beam big bushes colour orange then used my car at the weekend and it felt like i had rear wheel steering i checked every thing thought somthing was loose but it was all tite in the right places then i checked for play in the rear wheelbearings only to find out the rear beam was moving side to side has any body els had this problem?
Old 15-05-2007 | 10:49 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Only with inner-edge-worn rear tyres
Are the donut bushes secure?
Old 16-05-2007 | 08:52 PM
CosKev3's Avatar
CosKev3
Default Re: rear poly bushes saff cosworth
Get a pic up of the bushes in place m8
Take it they are Deflex ones being orange?????
You've obviously pressed the big donut into beam,did you use the smaller round bush too?????
Old 17-05-2007 | 05:48 PM
madmurdy's Avatar
madmurdy
Default rubbish rear polly bushes for a cosworth
hi there yes ive fitted the small ones aswell but im not sure if it fits between the chassy or fits under the big bush then the 3 bolt plate? any way ive tryed both ways it seem like it should fit under the big bush as it presses the big bush harder making it fit titer but it looks wrong but it done the trick so i am going to make 2 big round 12mm thick steel washers and weld them to the 3 hole plate then fit it should press the bush in harder to make them swell for a good tite fit
Wilsfoci
15
30-03-2016 10:26 PM
Anutternutter
24
31-08-2015 01:24 PM
Bosch
23-08-2015 12:31 PM
Anutternutter
21-08-2015 06:07 PM
James Porter
14-08-2015 12:43 PM
Quick Reply: rear poly bushes saff cosworth
