2wd Calipers onto 4wd car
Originally Posted by Rousesportcosworth
4x4 calipers aren't 4pot!!
Think the point thats trying to be made is why do you want to downgrade your brakes?
ahhhh fuck sorry i read the first post wrong
if the hubs are the same (i know little about sierra's) then they should fit!
Brake pipes may an issue though, being as a 2wd is rear driven, when we fit these calipers on Escorts the brake pipe connection points out at the CV joint.............
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Get on That!
4 pots are way better than the single piston sliding caliper which are just about able to stop a bicycle!!
Rousesportcosworth, are you sure yours are two pot as they are only ever single piston sliding caliper of the "PROPER" ones four pots ?
4 pots will fit, just tap out lug holes to take a 12mm bolt and tap top suit, then straight on fit, you MAY need 1 or 2 1mm washers under lugs to just centralise a bit.
Having gone from 4x4 calipers/discs on my old sierra to 4 pots(cossie) the difference is like the difference between a milk float and a F1 car in performance terms!!
I recommend EBC REDSTUFF CERAMIC, under no circumstances use GREENSTUFF(V4)!!
More boost Igor!
Also bear in mind the possible reasons Ford didn't fit 4 pots to 4x4s:
1: Cost
2: braking power - 4 pot calipers are more powerful (waits to be corrected) than the single pot 4x4 ones, and could spell bad news for your front diff when used hard often. You'll need the advice of someone who's fitted proper front brakes to a 4x4 for a second opinion.
In addition, the 4x4 has vented rear discs to improve rear braking power, as opposed to 2wd solid discs which really are better suited to bicycles.
1: Cost
4x4 vented discs merely give more fade resistance, NOT stopping power as the size therefore the leverage ratio is the same.
It is due to having more rotating mass to slow ie extra driveshafts, transfer box, diff.
jason_nike
18-08-2019 10:53 AM
rog
04-09-2015 12:10 PM
lockie
31-07-2015 10:03 PM
