202 block
Old Jan 9, 2004 | 10:15 PM
the original's Avatar
the original
Default 202 block
what's the latest opinion on 202 block versus 200 block?
i know the 202 block can't be longstudded, but i'm talking about high boost with standard bolts and 3 layer headgasket?
cheers
Old Jan 9, 2004 | 10:51 PM
why cant it be long studded?
is this because of what i said a while ago about the head bolt holes not being as deep? this is what a local cosworth garage told me but i think they were just trying to sound clever and were tellin me porkies mate
basically they sound identical to the 200 block but without the rear plug, so that can only make them stronger than the 200 really.
why have you got one cause i thought they where all long gone? or are you considering that one on ebay with the pistons?
Old Jan 10, 2004 | 03:34 PM
the original
no i've got one mate, i'm building it up at the moment, my opinion is it seems at least as good as 200 block, i'll measure the depth of the holes and post here...
Old Jan 10, 2004 | 03:53 PM
the original
haven't got the thick bore walls to halfway down like rs500 block (and 200 block?)
Old Jan 10, 2004 | 09:35 PM
really
now that is interesting!
what part are we talking about here?
Old Jan 10, 2004 | 10:02 PM
the original
what the thick walls? when i was at grove they were building an rs500 engine and if u looked through the water pump hole you could see the thicker bore walls. don't know if 200 have this...
plenty of people reading will know....
Old Jan 10, 2004 | 10:11 PM
hmmmm i have a spare 200 block sat in my garage so will have a look next time i go home.
Old Jan 10, 2004 | 10:17 PM
Sapphy's Avatar
Sapphy
When I was over at SCS I had a chat with Harvey Gibbs about the 202 block. They are slightly better than a 205 block but not as good as the 200 block. They basically are only good for a standard rebuild, are considerably cheaper than a 200 block and have less core plugs which would help make the water jacket slightly stronger.
The bad points:
- The piston bore walls remain the same thickness throughout whereas the 200 block's gets thicker near one end
- They cannot be long studded like the 200. Harvey held up the 2 blocks and showed where the 200 had meat to drill into and the 202 didn't.
They therefore a not seen as being the block of choice for higher powered engine. Also, the supply of them was brief and small, so you are unlikely to hear of them again.
Hope this helps!
Old Jan 10, 2004 | 10:24 PM
the original
cheers
i read that on your post on turbosport a minute ago
Old Jan 11, 2004 | 01:11 AM
fek me ! i was just about to buy one aswell , i posted on here about a month ago similar question , looks like im back in the game for a 200 again then
Old Jan 11, 2004 | 01:44 PM
Alvyn's Avatar
Alvyn
made for Transits and thats where they should be! all imo that is!
Old Jan 11, 2004 | 10:59 PM
Sapphy's Avatar
Sapphy
Originally Posted by the original
cheers
LOL! I was too lazy to type it again so copy and paste!
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
