power steering
Old Apr 8, 2007 | 01:05 PM
k1rky-b0y's Avatar
k1rky-b0y
Default power steering
just had a problem with my power steering it has started goin in stages as i turn the steering wheel and now its realy heavy.but the belt is ok and the pump sounds fine.can anyone help. this is on an escort cosworth
Old Apr 8, 2007 | 02:11 PM
GAZ345's Avatar
GAZ345
check the joint from the column to the rack, spray some wd40 in it
Old Apr 8, 2007 | 03:06 PM
Check the fluid level first, then if all things as they should be you have two things left, rack or pump is knackered!!
Old Apr 8, 2007 | 09:31 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
also, check the belt is tight!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
