Loosing Water
Old Apr 7, 2007 | 07:41 AM
bpspa's Avatar
bpspa
Default Loosing Water
took the escos out yesterday, came back and parked on the drive to find the header tank completely empty and its contents on the drive.
Had a poke around but can't pin point exactly where its leaking from, its somewhere from the front of the engine, its definately not from the thermostat housing but a bit further down and its leaking all over the pulleys.
Have filled the expansion tank back up and it holds the water until you take the expansion cap off or squeeze the rad hoses.
Anyone got any ideas on what might be leaking?
Old Apr 7, 2007 | 07:53 AM
If it leaks just by squeezing a hose it sounds like a bad leak so should be easy to find ?
Try to get someone with you to look while they or you do the hose squeezy bit, or try some compressed air say 5 psi in there if you have a CORK bung and compressor, you will then see it weeing!
Obvious place is the w/pump, seal ?
Old Apr 7, 2007 | 09:02 AM
garyrs's Avatar
garyrs
yup water pump is deff below themstat houseing , use somewater leak finder stuff , can get it from motor centre and comes out a bright color were the leak is. gary
Old Apr 7, 2007 | 09:33 AM
bpspa's Avatar
bpspa
Managed to get a couple of piccies, although its from the top at the moment.
Its coming from below the part (the one thats rusty) just right and below of the thermostat housing and left and below of the tensioner.
Had a look at some piccies I have found form Ford showing the thermostat housing it does look the right place for the water pump but not sure.
How easy is it to remove the water pump on these, doesn't look much space?
Old Apr 7, 2007 | 12:21 PM
garyrs's Avatar
garyrs
yup the rusty thing sure looks like the water pump, i took mine off in about 25-35 mins, but i have a 2wd, with diffent pipe positions on water pump and therostat houseing so not sure how hard it will be , cant see it takeing much longer,gary
Old Apr 7, 2007 | 03:22 PM
Easy to do just a lot of stuff in the way.
Old Apr 8, 2007 | 06:13 AM
bpspa's Avatar
bpspa
thanks for the help and pointers guys, will give it a try when I can get a new pump
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
