Mk4 Diesel van
Old Apr 4, 2007 | 08:32 PM
escort_lx's Avatar
escort_lx
Default Mk4 Diesel van
Would it be possible to fit a head from a TD engine to my mk4 escort van as its just a 1.8d, also does anyone know if the turbo will fit with the bulkhead as i believe the mk4 diesels never used turbos.
Sorry if this is a silly topic
Old Apr 4, 2007 | 09:42 PM
ZVH,RST's Avatar
ZVH,RST
yes it will fit, and the turbo, but you will have to mod the down pipe and make a turbo return pipe to the sump or block, it would be easy just to swap your engine for a complete td engine,as the fuel pumps are not the same,as your non turbo diesel.
Old Apr 5, 2007 | 07:19 AM
The only head differnce is sodium filled exhaust valves on the turbo.
The pump can be swapped over too, but you need "management" of some kind.
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
atm
Sep 7, 2015 05:39 PM
Bighandsuk
Sep 2, 2015 05:23 PM
