HOW TO TUNE PROPERLY A COSWORTH ENGINE??
Old Apr 4, 2007 | 03:10 PM
DANROM's Avatar
DANROM
Default HOW TO TUNE PROPERLY A COSWORTH ENGINE??
Hi peolple.
I would like to know how to tune a cosworth engine without having any computer program or any diagnosis machine.
What I want to know is how to set the boost, the fuel, the air/fuel ratio, to the old style, as where I live there is no one with cosworth knowledge.
So I have to do it by myself
Old Apr 4, 2007 | 04:42 PM
davidnormanuk's Avatar
davidnormanuk
You might be better off asking this in the general discussion part as there seems to be alot of people with Cosworth knowledge in there.
Dave
Old Apr 4, 2007 | 06:24 PM
Boost is set by the chip and actuator.
AFR is set by fuel pressure versus chip, open time for injectors.
All you need is a decent chip like MSD, then make sure your fuelling is ok on Rolling Road, ignition timing set by trigger points on crank pulley wheel.
Idle CO set by mixture screw on ECU.
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
